1 - 3 of 3 Posts
Just picked up a 99 4 runner V6 3.4 with
Blown head gasket with 170k,
Need recommendation
Just do the Heads
Install a Used engine
or
Find a reasonable rebuilt engine
I am on a budget
1995 T100 2WD & 1993 MR2
My T100 has the same engine. If the diagnosis is correct then I'd just do the heads. While things are apart put on a timing belt kit with the tensioners,water pump, thermostat etc. These engines are close to bullet proof.
You'll keep within your budget with less work and a known product that belongs in "that" 4runner when your done. IMHO
PS Be sure and use new head bolts!
1 - 3 of 3 Posts
