If the issue is what I think it means... partially install the lower cover so you can use the timing markers. place the harmonic balancer on the shaft but do not seat or install the bolt. Turn balance wheel to "0". Use a marker and place a reference line somewhere you can line up the balancer with. Gently remove the balance and lower cover and place additional alignment marks with the marker on the front of the engine so you can see if the wheel has moved. If you are not sure you have it correct you can always put the lower cover back in place and slide on the balancer to check it is on zero. The top is just turn the cam till the marks line up. Hope that wasn't confusing.
