I guess I did my research but did not explain the problem.
The fan is always running at high speed even when the AC is off. I checked the fuses (terminals) in the relay box and all seemed to be okay.
If I unplug the connector from the fan switches on either side of radiator, the fan stops. If I take out the fuse from the relay box, the fan stops.
As I understand, this problem could be either due to coolant sensor (engine side) or coolant switch (radiator side). Since I am not getting any
CEL, I assumed the problem is not with the sensor but the switch. The fans are running at fail safe mode.
When I tried to take the connector off the coolant switch, the plastic part broke off. It could be some internal rust in the switch. Since the switch
is broken, I need to replace it and hope that fixes this problem.
