Okay, I just got my first toyota, a 1999 camry with a 5sfe engine that has about 260,000 miles on it. after I got it home, I discovered it leaks about 1 qt of oil in just under 100 miles, and then the oil level stays put at 1qt low.
I saw oil dripping onto the exhaust from the area between the engine block and the transmission, and smoke coming up from the same area on top of the engine as this oil bled out, all of which stopped when the 1st quart disappeared.
I saw what looked like a sloppy sealing job with clear silicone along one side of the oil pan, so I assumed it needs a new oil pan gasket.
So I bought the felpro gasket, some of the Permatex black RTV silicone, put the car on the ramps, drained the oil, and got ready to remove all the bolts around the pan to drop it & clean it up
Then I found some ALIEN TECHNOLOGY . . . :surprise:
( Keep in mind, I'm used to working on 70's & 80's GM & Dodge vehicles, and an occasional Datsun or Subaru for family members. My newest vehicle I've worked on (or under) was my '97 Chevy Lumina, until it's disposable transmission wore out and I got this Camry.)
ALIEN TECHNOLOGY: Why in blue blazes is there some sort of a custom molded, foam rubber SPONGE molded into the (external) gap between the bell housing and the oil pan????
Is this something Toyota did?
This sponge thing was saturated with oil, and it crumbled to little black pieces when I touched it. Until then, it was molded into filling the gap between the tin inspection cover over the bottom portion of the bell housing, and the back wall of the oil pan, below the rear main seal. The tin cover over the lower bell housing had a pair of pins, or tubes, about 1 inch long each, that almost bridged the gap between the Bell housing and the oil pan, this foam sponge thing completely enveloped these protrusions, was held in place by them (until I crumbled it up) and extended the full width of the oil pan, and was almost as deep as the shallow end of the pan itself. (I would photograph this thing, but there isn't much of it left). There were no bolt holes in the lip of the oil pan from corner to corner above/behind this sponge-like device. Could this absence of bolts be a pressure vent of some sort? or a Toyota's effort to protect the carrier of the rear main seal directly above it?
All the surfaces behind/underneath/covered up by this sponge were saturated with motor oil, and oil was dripping from the end of the sponge pointed to the rear of the car, drips were sometimes landing on the hot exhaust and burning (or smoking) while the car was in motion. The exhaust flex-joint, and much of the exhaust pipe going back was black from this going on for so long.
My question is this, I need background on this mystery part!
was that sponge thing Toyota's idea?
(I have my suspicions, but ... )What was its purpose?
must I replace it? Is there something better to use now? (nobody I spoke to about this Camry ever mentioned such a part before, & I haven't seen such a thing for sale at rock auto)
(So much for a simple R&R of the oil pan gasket!)
I want to understand my soon-to-be daily driver as thoroughly as I can, so any info is appreciated.
