I recently moved from an at sea level town in Massachusetts, to about a 7,000ft elevation in California. My 1999 Camry made it across the country and around SoCal for a few days until it overheated on my second drive up the mountain. The check engine light came on and the temperature gauge spike up to the red zone, and the antifreeze had started to boil and steam out from underneath the hood. I had the car towed to the Toyota dealership a few days later, and by then the check engine light had gone off. The dealership ran a diagnostic, and both the radiator and reservoir were empty of coolant, and 2 trouble codes were stored in the memory (engine coolant temp circuit malfunction and evap. Emissions control system vent control half) The cooling system temp was as high as 280 degrees F, and it passes a cooling system pressure test w/ no visible leaks and pressure holds. It also passes a block test. They verified that the fans are working properly. They also replaced the thermostat and gasket.
I went and picked the car up today, and drove it for about 50 miles around Southern California, before heading up into the mountains. It made it another 30 miles before the same thing happened – overheating with the antifreeze boiling in the reservoir and steaming out. There is currently no coolant in the vehicle. I am completely perplexed as to why this is happening. Additionally, the a/c in the vehicle only works on the highest setting. When I picked it up I drove about 5 miles with the a/c on, and it was blowing cold air. I made a stop (turning the engine off) and when I turned the car back on, it a/c would only blow warm air. Could there be a possible relation between this and the fact that my car is overheating? Could it have anything to do with the altitude?
Any help before I bring it back would be appreciated!
