1 - 10 of 10 Posts
Hiy everyone, as title says I have a 1999 Camry v6 3.0 with about 305,000 miles on it. Runs well, I just finished replacing the O2 senors on it. The one on the manifold and the one by the firewall. I believe they are bank 1 sensor 1 and bank 2 sensor 1. Prior to replacing the O2 sensors it gave me codes p1135 A/F sensor heater circuit malfunction (bank 1 sensor 1) as well as code p1155 A/F sensor heater circuit malfunction (bank 2 sensor 1) . Those codes were erased after being replaced. Drove it around for 40 miles now I am getting code p1133 A/F sensor circuit "response" malfunction (bank 1 sensor 1). Any advice or help would be greatly appreciated. Thank you in advance. Sorry for the long write up.
· Administrator
What brand of sensors did you install, and where’d you get them?
Reactions: oldschooltoy99
Discussion Starter · #5 ·
Do you have a CA emissions car with A/F sensors? You said you replaced O2 sensors. Also bank 2 sensor 2. Was that a typo? If you installed anything but genuine Denso sensors you will likely have problems. Hopefully you didn’t buy junk from eBay.
Yes I have a California emmisions car as I do live in California. Yes sorry for that it was a typo. Bank 2 sensor 1. I did purchase from Ebay. Smh. Should I purchase a whole new pair you think? Of Denso? Thank you Artbuc1. Appreciate your response.
· Administrator
The P0125 is a sympathy code to the O2 sensor code. Fix that, and it’ll go away.
I suspect the new sensors you installed are junk. Can you provide a link to what you bought on eBay? Recommend you get Denso sensors. Look up the p/n you need here on Denso’s website, then get them on Rockauto.
Discussion Starter · #8 · (Edited)
O2 Oxygen Sensor Upstream Air/Fuel Ratio For Toyota Sienna Camry Lexus RX300 G1R | eBay
That is the link to the oxygen sensors that I purchased. Ill check that website out. Let me know what your think of those sensors that i purchased. Thanks.
I purchased those due to the fact it said it had California emissions. So I should purchase Denso to just be sure, correct?
Are the air/fuel ratio sensor the same as the oxygen sensor?
No. The California cars use A/F sensors and the Federal cars use O2 sensors. If you have precats you know you have Cali emissions, in case your label is missing under the hood.
For $20 I am certain the sensors your purchased are a hoax.
Denso is what you want.
Discussion Starter · #10 ·
Thank you Seve108 I am going to purhcase some Denso sensors sometime this weekend and see how that goes. Again appreciate all the help.
1 - 10 of 10 Posts
