1 - 8 of 8 Posts
I did a search but couldn't find the answer. Posting on behalf of a friend:
I'm working on a 1999 Toyota Camry XLE 3.0 engine. I'm doing both CV Axles replacement. What is the axle nut torque? 217 ft lbs?
Thanks in advance for the help.
Various Toyotas
I meant to add that there is some controversy about using an impact wrench on that axle nut (even if using a torque limiting extension). There are those who believe you shouldn't impact that nut on. Just turn it with a manual wrench, then use a manual torque wrench for 217 ft. lbs. It's just an opinion I've read, so the choice is yours.
1993 Camry SE,V6-5MT
By the way, if you only own a torque wrench that goes up to 200, there are two solutions:
borrow a bigger one from your local auto parts store
Stand on a bathroom scale, use a 2 ft long breaker bar and push down until your weight is reduced by 108lbs (108 x 2ft = 216 ft lbs). Just be careful that you push AT the 2 foot mark, and not somewhere else (or do the math so you know what your target number is at whatever place you DO push).
By the way, a tool that goes up to 200 is not considered accurate at that number. A good rule of thumb is to have a 20% margin to either end of the scale of any force measuring tool you use.
Norm
Various Toyotas
Norm
Well........I learn interesting things every day! Never would have thought of something like that. Cool!
I purchased this torque wrench for when I need higher torque and have been very happy with the results, especially for the price:
1 - 8 of 8 Posts
