1 - 4 of 4 Posts
I have some vehicles I am religious about checking my oil level on. The 4Runner is not one of them. It is my wife's vehicle and unless we are going on a long trip, I have a fill it and forget it attitude towards it. Part of the reason I bought it was it should be able to handle that kind of ownership (abuse? o_O).
On today's oil change, I only drained about 3 quarts out. I have been using full synthetic since I bought it. 7-8k mile intervals, roughly 2x a year. I don't remember how much oil I have drained out of it in the past, but I would like to say I would have noticed if it was this bad. I have never seen any oil on the ground or in the engine bay. It runs like a dream, and I have never seen/smelled it burning any oil. I dumped in 5qts and the oil level is just a touch below full, which makes sense.
The way I see it, I am either burning off 3 quarts without noticing, or I have 3 quarts of sludge in the heads. I didn't think there was much worry for sludge since the early MZ's. Is sludge something I should be concerned about with the 1GR? Any recommendations for desludgeing this beast?
2001 Camry LE
Unless the 3 quarts that you drained out was black, I doubt it formed into sludge. Much more likely that it burned. 2 quarts over 8K miles, or 1 quart over 4K miles, is probably not too much to worry about. Keep an eye on it and see if it gets better. Could be a bad PCV valve, or maybe just an old engine. I think a lot of manufacturers claim 1 quart of burned oil over 4-5K miles is "normal" on their new cars, even.
Alternatively, it could be leaking oil? I usually park on the street and I didn't realize my car was leaking until I parked it in the driveway for a few days.
The oil was definitely pretty black. I only put 4k or less on my oil so I'm not sure what I should expect 8k mi oil to look like. I didn't think it looked lumpy or anything though.
PCV valve is a good call though. 115k on the truck.
2001 Camry LE
If you are concerned about sludge due to the black oil, I'd try shortening the OCI to 4K with fully synthetic oil for a few times and see if the color of the oil improves with each oil change. You might even want to be aggressive and do one or two changes at a 2-3K interval to see if the oil does come out really dark. Oil changes would be pretty cheap since you're doing them yourself.
1 - 4 of 4 Posts
