I would say the 2JZ-GTE is the better engine, and there is probably more parts for it.mongoldrifter said:whats up guys
i have some questions. i'll be using the car for street/drifting.
1. 1jz-gte vs. 2jz-gte? both have 280ps, one is 2.5l and the other is 3.0l, both twin turbo... so which one has greater potential?
2. should i get a sx90 with a 4s-fe 120ps under $1k and swap the engine with 1jz-gte or 2jz-gte, or jzx90 tourer V with 1jz-gte 280ps, and if i get the jzx90 should i swap the engine with 2jz-gte? either one i get i have to have blow off valve, turbo timer, lsd, coilovers. so with all these mods which one would be cheaper?
thanks, any comment is appreciated![]()
OTOH, the 1JZ-GTE was a more popular option for the 70 series Supra than the 7M-GTE. So, displacement isn't eveything.
Good luck shoehorning a JZ block in a car designed for an S block.
- John
