1 - 9 of 9 Posts
The Greatest
If your thinking about forced induction, Its usually good to just upgrade the internals w/ your F.I.
Im not sure about the hp part but Stock internals can handle around 6 psi. So i guess it varies. I don't know how much hp you can get runnin 6 psi but if you want more power, you'll prolly run a higher psi. Which means you should upgrade internals.
The Greatest
Toysrme said:
You can't say an engine will take X amount of PSI. Every turbo is different. Thanks Tony ;)
That is quite true. But in most cases. You will be safe running 5-6 psi. But that is taking a gamble because of what you said. Every turbo is different.
Grenaded piston
1 - 9 of 9 Posts
