People!
2004 TRD Taco V6, 94K miles, always maintained, oil, water pump, timing belt, etc.
today the check engine light appeared. What could be the cause? Oxygen Sensors?
Thanks from So. Cal.
Moved your thread here from the introduction forum to the 1st gen Tacoma forum. These guys can help, but you'll need to pull the code to help isolate the problem.
Welcome to TNation:welcome:
Welcome to the Nation. You'll need to get a hold of an OBD2 scanner and pull the code(s) to see what is causing the CEL then you can start diagnosing from there. Just telling us you have a CEL and us telling you what it may or may not be is just a guessing game. Go to AutoZone or borrow an OBD2 scanner and see what the code(s) is/are first, good luck.
