08 HLS
so the water pump just went at 40k miles. it's covered by the 60k powertrain warranty. There was a constant knocking sound at idle/engine on near the lower left passenger side of the engine. The sound was probably coming from the water pump bearings. You can hear it clearly with the hood opened.
if you noticed anything similar to that on your vehicle, get it checked out asap. If the pump shuts down completely, your engine will overheat and that's really bad for the engine.
