After replacing the starter in my 1991 Corolla, I noticed a cable that was coming off from what I believe is the top of the throttle. It is still attached there, but the other end was just hanging down. As I was looking around to try and find where it was originally put on, I noticed a 2nd cable/hose that was coming from something under the master cylinder, that was also not connected to anything. This one was running up from that over the air intake hose and then back down, near where the first hose was hanging. When i replaced the starter I did remove the air intake hose and air filter box and at the time did not notice them. It was only after putting it back in did i notice that they were not connected to anything. I have spent time trying to find out what these are called or what is below the master cylinder. The cables/hoses themselves are relativley thin and flexible. And at the part that was just hanging is a hole and right inside the cable/hose looks to be some insulation that is a greenish color. Any advice is appreciated.
