2000 Toyota Camry (LE - 4 Dr) Mfg: 02/2000
VIN: **********YU102877 Model: MCV20L-CEPNKA
C/TR: 1C8/FB69 Paint Color - Lunar Mist Metalic 1C8
A/TM: -02A/A541E
Model MCV20 - V6 Gas / 1MZ-FE 3.0 Litre Motor
Hope someone has the answer. Drivers side rear door damaged. Salvage yard has a good door from a 1998 Camry that they say will fit. They say the driver side rear door is the same from 1997-2001 other than color, but the rest of the door is supposed to be the same. But in looking at a picture of the outside of the door from the 1998 the door side trim piece is clearly different that what is on the 2000. The door side trim can be purchased new from Toyota, dealer says that this trim is only available primed (colors no longer available) but as shown here the door side trim piece is different on the 1998 vs the 2000 and pictures show this. Question here is, is the outside door metal/skin the same on all Camry from 1997-2000? If so any door side panel trim piece for a 1997-2000 will fit on any door, but I question this since as pics show the door side panel trim piece is clearly different on the 1998 vs the 2000. But will these trim pieces fit any door without some sort of modification?
Anyone help here? Is the outside drivers side rear metal door skin on these doors all the same (other than color) on all Camry from 1997 to 2001? If so then I can put any door from 1997-2001 on my 2000 Camry and can install the currently available side trim piece which is the wider version like what is on my 2000 now. I do not want to purchase the 1998 door from the salvage yard if the outside metal is not the same as on my 2000. I do not want to have to modify the outside of the door to fit the trim piece. Anyone? Anyone done this?
According to Toyotta dealer the Camry drivers side rear door side panel trim piece is 75742AA904 (primered). Dealer says the colored trim pieces are no longer available. In past colors were available but evidently no more.
SEE PICTUES. LOOK AT DIFFERENCE IN WIDTH SIZE OF OUTSIDE DOOR TRIM PIECE. The vehicle with the wider (wider up and down) side trim piece is the 2000, the picture with the narrower side trim piece is the 1998. See the difference, one trim piece is wider (evidently wider on the newer 2000-2001 vehicles). Question is, is the outside door metal skin that this trim piece attaches to the same on all 1997-2001? If so then any 1997-2001 trim piece will fit on any 1997-2001 Camry rear door. The wider trim piece is evidently what is available now, I assume that because my newer 2000 has the wider trim piece, but I am not really sure. Anyone?
A/TM: -02A/A541E
