1 - 2 of 2 Posts
2000 Corolla CE
Hey everyone, first post here but I do lots of vehicle work for myself and family. That said, transmissions, especially AT's aren't my thing. Dang slushboxes.
We have a A245E transmission, 2000 Corolla CE with 240k on the ticker that would shift into reverse but had no power at all, after much testing determined it to be a severely worn band or clutch pack.
So I found an A245E(an 06) locally that I thought would work but have discovered the really hard way that the plugs at the neutral/park switch and the solenoid connector are very different. It is also lacking the kick down cable that mine has.
I just finished mounting it into the car and was finishing things up when I finally realized the plugs were different.
Is there a workaround for this that's less labor and money than finding another transmission and installing that?
For the neutral/park switch I have already swapped them over so that seems ok, but the solenoid plug on mine is 3-wire, the donor has a 5 wire plug.
Then there is the matter of the kick down cable.
Thank you,
Joshua
1 - 2 of 2 Posts
