Are you thinking that you need to replace the button or the trim bezel? I think the whole trim bezel will have to be replaced because it appears that the tabs/clips that hold the button in place have snapped off. Maybe it is the other way around and the tabs/clips are broken off the button...
Do you have access to a Pick'n'Pull or similar salvage yard?
I do, but I'm not going to ppoke around in a record Michigan winter looking for parts for a 2000 thats why I am asking for part numbers to go on car-parts.com or ebay to find the parts
Hi Guys ,
As i was changing my headlight bulb i have snapped the bolt on the right hand side of the headlight in drivers side the headlight it's still in place with the other 2 bolts but feels a bit insecure is there a website i can buy the same bolt i have been looking but no luck :(
And...
Hello everyone.
I've been ramping up work on my Corolla lately, and the next port of call has been to eliminate the vibration which occurs at idle, once the revs drop down to normal, after the engine has reached operating temperature.
The mechanic who inspected the vehicle for a roadworthy when...
Hello: I have a 1998 Corolla and the horn sounds very sad. I would like to replace it. Does anyone have a recommendation for a good (preferably louder!) replacement that won't tax the 10 amp circuit?
It’s driven 100 miles one month ago, and has been sitting since. Odometer reading 241k km, i.e. 150k miles, originally from Canada. Now I can’t start it, and can’t jump start it. The console lights and inside cabin light come on just by the battery, but no cranking sound at all even when using a...
