1 - 3 of 3 Posts
Hi All have code on my 2000 echo trying to read it i have can obd 2 eobd code reader but it does not read code i notice socket where plug in code is loose can move a little up n down is this normal or it not suppose to have any play in it . Also is there a way to read code another way Auto zone n advance auto near me do not read codes no more so i can see if its socket or code reader Thanks
I'd suggest the lack of replies means no one's had a similar problem...but my 02 Echo's OBD2 port is firmly affixed. No up & down movement at all. In fact none of the cars I've seen have had movement there. Hopefully by now you've found a workaround (or a fix).
1 - 3 of 3 Posts
