So my 2000 Echo has been running great, no complaints at all. Then one day car won't crank, so I jump it and it starts fine and takes me to and from the grocery store. Next, it fails to start again. Hook it up to the batter charger, and it quickly (<15 minutes) goes to very low amperage, so I figure battery (>= 6 years old
) is dead and take it to the parts store, where they confirm this.
I buy a new battery, pop it in the car and attach the cables. I crank the engine and it starts right up like it always has, so I install the battery hold- down go eat dinner. A few hours later, I try to start the car again and it cranks but will not start. I can hear the engine combust a bit, and it almost catches, but then it just cranks.
It occurs to me now that I accidentally tapped the negative terminal with my wrench when I was tightening the positive terminal. It gave a slight spark, but it was so fast it didn't even make my wrench hot, and since the car started up like normal right after this, I didn't really give it any thought. Could this have caused some problem?
I've checked the EFI fuse, the EFI main relay, the circuit opening relay. I've checked for voltage at (and between) the EFI main relay and circuit opening relay with ignition off and on, there is voltage at the proper times (according to the wiring diagram). I've checked the spark at all four cylinders (and replaced the plugs in the process of that--I did gap the new plugs) and the fuel pump operates both on manual application of voltage and when you crank the engine. I have not checked fuel pressure, I don't have a pressure gauge (but the gas sure was flowing when I detached the fuel line). This car gets driven almost daily, so old gas shouldn't be an issue. I've hooked up my scan tool and there are no DTC codes and no freeze frame data.
Does anyone have any ideas? Where do I go from here? I really don't have the money to take this to a mechanic right now, so if anyone has some pointers I would be much obliged.
