1 - 6 of 6 Posts
I have a 2000 solara sle..i went to work it was running fine I got off work and it only cranked but wouldnt start. My friends and I have checked fuel pump, relays and spark plugs..the ECM reads good sometimes and bad other times. Im not much of a mechanic and I don't know what could be wrong. Please help
Super Moderator
2006 Corolla XRS
Check your battery terminals are tight on the battery posts. Also look for any corrosion. It would be a green mess if there's corrosion.
How old is your battery?
Do you have a digital multimeter? Check voltage across the positive and negative terminal. You should see around 12.6 volts.
Also visually inspect for a cracked housing case on the battery.
Then check Google to make sure you have the correct size battery for your solara.
Easiest way to narrow it down from here is spray some starting fluid in the intake, if it starts then dies down it's a fuel issue. If not, it's a spark issue. Sounds like it will crank over but not start so checking battery is not a priority at this stage.
Look in sig
This too help to troubleshoot.
Is this a V6 or I4 ?
1 - 6 of 6 Posts
