1 - 4 of 4 Posts
Parked my tundra one day after running fine, and now it won't start unless I spray starting fluid into the intake. Has anyone heard of this issue before? Its's leaving me and a friend stumped so far. Thinngs I've tried so far will be below.
Different ecu
Checked fuel pump
Different battery
Battery connections
Checked fuse/relays
Thanks for any help
Once it starts, will it stay running and drive normally?
Will it start normal once the engine is warm?
It stays running normally once started, I did not try driving it.
No it would not start when warm, mechanics scan tool said engine was reading 185 degrees when we tried restarting it.
I started it with starting fluid letting it get up to temp and the truck died while idling. Does anyone have any ideas what might cause this issue?
1 - 4 of 4 Posts
About this Discussion
2 Participants
myfirstyota
Toyota Nation Forum
Full Forum Listing
