First, I was not able to start the car in two tries 5 days ago. See here:
http://www.toyotanation.com/forum/1...o-start-symptom-after-iac-valve-cleaning.html
Today I tried 6 times and it still would not start. The car did crank. So I had to think of something else. This is what I did.
1. I shifted to neutral and tried from neutral. No go. So not the neutral safety switch issue.
2. I shifted to neutral, depressed gas paddle, then tried to start. The car finally started after some struggle. So it has to be either air or fuel.
3. I left the car in idle and it did not die afterwards.
So what is the issue now? If it is a clogged IAC, why didn't the car die afterwards when idle? I did clean IAC valve a couple of weeks ago. Is it possible that I messed up something last time?
If it is fuel problem, what should I proceed to further diagnosis? I have a bluetooth dongle with Torque Pro installed in my phone. Is it going to tell me something I do not know?
Thanks a lot for your help. Ideally, I want to precisely pinpoint the issue and solve it. Any help is greatly appreciated!
