1 - 4 of 4 Posts
What is the correct idle rpm cold for a 2001 Camry 4 cyl. The following details may be appropriate. Ambient temperature 52 degrees F. Immediately upon starting rpm goes to approximately 1700 rpm in about 5 minutes it will settle at 800. Is this normal?
2010 Camry SE V6
2005 Avalon Limited
Yes it is. I have an 05. But b4 that i hade the 2000. It is just the automatic choke. B.c if it idles to low at startup it will stall. THats why they make it do that. Its normal
Gen 4 XLE v6
02 Toy Solara V6 MT
When its cold, the car automatically raises the rpm's to speed up the warming process, its all normal! I've had rpm's till 2K rpms in cold cold wisconsin winters, that was loud!
For 52 degrees that sounds a little high for much more then a minute. I would check the cooant temp sensor. In really cold weather it might be a little closer to normal. My 04 will start up high but will start dropping after 30 seconds or so.
Gary
1 - 4 of 4 Posts
