Greetings to all.
I love this forum and all the great ppl on it.
I have searched this site extensively for an answer to my problem but no success.
I have an 01 camry 5sfe, 124k miles. At 120k I changed the tb and water pump and replace the coolant. Immediately after, in traffic, the temp rises near the red before the fan comes on to bring temp back to normal. it seems that the cooling fan comes on too late. When i put the ac on, both fans are on and the temp stays in the middle. the temp is normal at highway speeds.Previous to the tb and wp, the temp always remained in the middle.
I have checked or done the following since:
1. replaced the thermostat with another Toy one and made sure jiggle valve is on top.
2. replaced fan switch even tho it check out ok. it went to open circuit at about 210 degrees
3. checked fan relays
4. Filled the cooling system several times using a large funnel sealed to the radiator opening.
Hope you can help.
Hope you can help.
