1 - 2 of 2 Posts
The cable for shift lock under the seats is cut and now the car starts but it won't shift out of park. Is there anyway to over ride this?
How did you end up cutting that wire in the first place? I mean if you're not 100% certain that the wire is related to the shift lock, I would check the fuse that releases the lock when the brake is pressed. It's one of the green coloured ones. Other than that, I would get it replaced if that is the right cable, as there is no way to bypass this without using the shifter.
1 - 2 of 2 Posts
