1 - 4 of 4 Posts
Okay I need some help with a battery terminal and fusible link. This is for my daughters 2001 Rav4. I started replacing the battery and the positive terminal broke. I went to get a new one but the parts store tells me is a dealer item. I go to the dealer and $22 later I have the terminal. This is were the problem starts. As I tried to remove the old corroded terminal the part that connects to the fusible link breaks off. Is this a dealer item only? I had asked them about the wire only and they told me $900 for the wire because it is a harness. They never mentioned the fusible link. Can any one help me?
Discussion Starter #2
fixed
Okay I was able to resolve the issue. I went to the dealer the dealer and got the fusible link $43.00, battery terminal $22.00, then a battery at the auto parts store $80, ordered battery cover clips $6.00 for 5 pack, from the dealer a case for the remote $6.00. Installed it all and it worked. Daughters face after telling her the cost - PRICELESS and then there is............
2008 Highlander Base
Thanks for providing the update. Are you going to contact the dealer and tell him what it really cost instead of the quoted $900?
I'm having the same issue that you had and went I went to the dealership they quoted me $900 as well. All I need is the fusible link and the positive terminal cable. What part number did you request? Or do you have the part number for the 2 parts? Thanks for your help.
Richard
1 - 4 of 4 Posts
