1 - 5 of 5 Posts
I cannot figure out why it still won’t run right after checking that the timing belt is lined up for the millionth time. Looking for any tips or ideas from you guys. It fires right up and sounds smooth for like a few seconds then stumbles and dies like it has a massive intake leak somewhere but I cannot find any hose disconnected. I get an engine code for multiple random misfires but no codes for anything else. What am I forgetting???? I’m at my wits end. 😩
328739
2004 Toyota Sequioa 1st Gen
Read this and see if it helps if you haven't already, specifically Joel_CA's answer.
That is a REALLY great idea!! Thank you. I completely forgot about that issue with Toyota’s. My sienna would have the same problem after an ecu reset. I’ll try it out and see what happens.
Ok so it is running smooth now. It was strange because it ran rough until I gave it a high rev (2,500+ rpm) then something got unstuck and it came back down to a smooth idle and ran perfect after that. Thank you so much.
1 - 5 of 5 Posts
