I have found only one shock absorber on the front of the engine. "others"? ThanksUsually if one is bad, the others are about to or have gone bad too.
The advantage is if yours are worn:
1. Less vibration
2. Will prevent excessive movement
Yes, there are other mounts that hold the engine / trans in the car.I have found only one shock absorber on the front of the engine. "others"? Thanks
