2001 toyota solara rocker panels replace.
516 Views 20 Replies 5 Participants Last post by  norm356
Hello I have a 2001 toyota solara both side rocker panels are rusted out. Did any one cute and replace them with new or a piece from a pick and pull?
1 - 20 of 21 Posts
Is your question does anyone on HERE (ToyotaNation) "cut" and replace them? Or are you looking for both your rocker replacements from a Pick-N-Pull that someone can pull here in the US then ship to Canada? Or are you looking for new OEM stock Toyota parts? Please clarify your question.
Sorry i should have explain it more. Did anyone here cut and replaced them? If so how hard is it to cut it? I am thinking taking a grinder and cute it off and get someone to weld it.
"Did anyone here cut and replaced them? If so how hard is it to cut it?"
Not on a Solara, but on a Camry. Grinder / cutter........... youll need a ton of batteries or if its air, the yard needs a long air line. I only use the saw
Really depends on your tools..and situation... If the car is on the ground good luck. Have them put it on a stand (our yard has a stand they put cars on) or have them lift it for you.
Absolutely inspect and check your car first and see what point the rust goes too so you know "how much" you need to cut. Always cut more than what you need. You can trim the cut piece. but if you cut too short, you'll need to go back and grab another piece or fab / do excess welding....
Again...
....measure not once, not twice but thrice..... then after doble checking your third measurement, slap yourself in the head and measure another time to make sure before you cut.
This is very helpful thank you. My Solara run great. It doesn't burn any oil and tranny shift smooth. Only issue is rust.
The key question is going to be how the rest of the body is. If just one rocker rusted out (typically due to a blocked drain hole) then its worth cutting out and welding in new steel.
But, if the whole underside is rusted and its just most visible at the rockers, then once you begin cutting out the rusted metal you might not have much of the lower body left by the time you reach good metal to weld to. Plus add that once you've done all that work you'll want to deal with other portions which will soon be at the same point. Unit body cars can be like that.
Reactions: 1
rest of the car looks fine. Specially frame is in very good shape. I am hoping to get 2-3 years out of it. I am sure it will run much longer than that but rust will kill that car before engine or tranny gives up. I had this car for 6 years most reliable car I ever own and I am not ready to let her go.
2-3?
How bad is the rust?
maybe you could just leave it as is.... maybe remove some of the most prominent flaky rusk and cover the rest with some rust encapsulator.
Removing and having someone install some rockers is a bit of work... and cost.... for only 2 - 3 years of service life IMO
As long as its not structurally an issue id drive it as is. .
yeh i could drive like this for two years or so but it looks ugly lol
Reactions: 1
Id personally leave it...but that's a good amount of metal missing! darn rust,
Also, before you do anything id ask the place you're planning to take it to, to see if the rest is structurally sound and ask:
1. Will they weld the piece on for you if you get the piece yourself? (some places wont touch your own parts / work). they also refuse to work on rusted cars.
2. How much they gonna charge!
So if i bring the parts only 400 to weld it and prime it. If they provide metal 800CA$
well........ that aint that bad then for 2 - 3 years of use...(around here youd be in minimum $2k just for the labor!!)
Be sure to ask them how far theyd want you to cut then. and tell them you'll cut a bit extra off too.
Id personally be inclined to go for the $800 option though...Im kinda thinking the yd just be patching it rather than replacing it though.
yeh that's true. I am just going to try cut off rocker panels from pick and pull and if I fail will go for 800. I guess its much cheaper option than buying anther old Camry or a Solara. 2nd hand car prices are crazy here. Even with rust i still can get 2500 or so for mine.
Reactions: 1
Sorry, rust stinks, MN Salt / Winter is taking over my 1994 Tercel...... so feel your pain
I have the passenger side 2006 Solara Rocker Panel Silver... already removed and in my spare parts. These are plastic. The rust rocker in Canada, could be cut front & back so the area is flat.
I would spary the rusty area with POR15.... this is a rust convertor that holds up well.
NO UV protection with POR15 so good for bottom of car, but needs to be spayed while still wet with a paint with UV block if any area is sun exposed. The bottom of auto is a good place for POR15. WE use it a lot in the classic 4x4 restor work. It is a black finnish.
Then use a body pannel adhesive to attach the 2006 plastic rocker pannel to the cut off , POR15 covered, area and will be a good repair. Rocks and debree get flug at the rocker pannel, chips the paint, and that is where the rust process starts.
My 2006 Plastic Rocker is not perfect, but in decent shape..... I would be happy with 100
Spay all the bottom with POR15, mask off the areas for maint, the rubber boots, etc
I have used HF Paint sprayer with can on top, used brass fittings so can tilt can so can spray upwards...
This worked well
Also from my research before you get rusty.... Thin Flim or similar product, there are 3 major ones, can be sprayed on bottom of car, the holes, the frames, and will keep the auto from rusting out. I purchased a FL Solara that is rust free..... will be using the Thin Film Spray oil coating on my ride. Needs to be done yearly or everyother year. The grandma car had been curb run over on passenger side.... had car avail that had decent plastic rocker replacement. I had not seen the car in person, so purchased the passenger rocker, passenger door, passenger fender, just because it may be needed and had access to a very nice solara that was rust free to pull these parts.
The rocker is long, but should be less likely to damage in ship vs a metal rocker would. This pannel was put in with plastic clips, the body pannel adhesive would be a great way to attach. Just will need few small jacks or similar. Could also pop rivet, screw. Could also have a body shop do it for your.
I think this would be good cost effective plan.
I am about 4 hrs south of border in twin city area.
Might be able to locate the drivers side rocker in plastic also??
We have a few solars at the local U pull currently?
This worked well
Do you mean "Fluid Film"? It is a very good protectant, and is lanolin based so it is also safe around rubber suspension bushings, fuel lines, parking brake cables, etc.
There are several products like it: Fluid Film, Boeshield (developed by Boeing), Wool Wax, etc.
Note that although these are easy to work with and they do a decent job of protecting metal, they are also rather thin and tend to rinse off throughout the winter. Being thin they penetrate well, and are self-healing, but I was finding rust blooms every spring even when I did avoid snow/salt periods.
Also, applying anything over the top of red, bubbling rust, is not very effective. Iron when it rusts expands tremendously and that creates microscopic pores with huge amounts of surface area for water and oxygen to get in contact in spite of what you'd tried to protect it with.
Optimal strategy (this is what I use):
1) wire brush / needle scale / sand blast off as much red as possible. Cut out badly rusted and weld in new.
2) use a phosphate rinse to convert any remaining minor surface rust to iron phosphate (Ospho is readily available at Ace (pints) and Sherwin Williams (gallons).
3) let that sit and convert for at least 24 hours, then clean real well with a good quality paining surface prep until your micro fiber cloth comes back clean
4) apply 2 heavy coats of the paint of your choice, POR15 is excellent, but as noted above it is not UV stable so you want to apply a top coat over it
5) after the paint has fully dried (at least 24~48 hours) then apply 3 heavy coats of Cavity Wax. There are several brands and all are good. Amsoil HDMP is good, but their applicator nozzle sucks, 3M Cavity wax comes with awesome nozzles, up to 36" long with 360deg spray nozzles for coating inside cavities, Cosmoline also makes tried and true cavity wax. Apply 3 heavy coats if working with aerosol. If using brush on, like Waxoyl, apply it heavy. Note that these waxes are petroleum distillates so they will eat rubber. Be careful not to get them on suspension bushings, wiring, hoses, etc.
6) let the wax dry to a tack free finish. It will hold up for many, many years, but is not self healing and does not penetrate into fissures all that well. So...
7) apply a heavy coat of FF (or the lanolin coating of your choice) over the top of the wax. Plan to touch it up each fall.
I apply the wax and FF outside and let mother nature clean up the overspray from the driveway (saves a ton of masking and cleaning in the garage).
Corrosion prevention is a matter of layers. Each layer protecting the one below, and providing a bonding surface for the one above. They will all fail over time, so more layers gives you more time, especially when working with old metal you can't get perfectly rust free.
Norm "I hate rust" Kerr
Reactions: 1
Norm356,
Thanks on the Fluid Film help..... I did not go back and look it up.
That is quite a list for a older rusty car 20 yrs old..... Maybe we can slow the rust down some???
The POR15 is great for the underside of auto.... and the sun does not shine there
Also on the back side of the quarter pannel with the rust hole (s) showing some
The POR15 likes...... LIKES.... rust and needs some rust to stick to the metal pannels
I would use a 4 or 4.5 inch grinder with a cup wire wheel, not twisted wire, HF has them for $5
Borrow a grinder if you do not have one.... will be 20 min of work at most..... do not go crazy.... just knock off
Pay for a lift location or have it done for you.
Make the cheap gun so it can point up and still have the paint can gravity feed.... ie brass fitting from hdw store
Then go to town and spray what you can see that is metal
It will slow down the rust.....
Before it dries and still tacky..... that is when the POR15 can be rattle can sprayed for a top coat
.................. NOT needed on bottom underside of car..... sun does not shine there
Apply the plastic SOLAR rocker pannels with a auto body adhesive with ouside rim of plastic rocker
Clamp in place or / and use some jack type devices..... let cure
This should get you the 4-5 more years out of the auto
Cost
2 Plastic Solara Rockers $50 local -250 mine shipped, POR15 & Wire Wheel $50, Auto Body Adhesive $40
If you want my rocker.... can take a pic and post here..... will not need to replace my rocker
NOTE
The Fluid Film was for other readers about rust control and help
Once this rusty the Fluid Film type product is waste of time IMO vs the POR15
Here are two videos.... the half hr watching can show much more that I or anyone can write on a forum
Best Car Undercoating? Let's find out! Is Flex Seal the Best Rust & Salt Protection?
2M views3 years ago
Best Rust Converter? POR-15, Eastwood, Rust-oleum Rust Reformer, Gempler's
Project Farm
2.9M subscribers
opps
Same Grinder with a cut off wheel can cut the rocker off, front side and back side in matter of minutes.... 15-20
Do not try and get flat cut off
Go back with grinder wheel and take the ridge left from rocker cut off.... knock it down to nearly flat
grinders cut off, cup wire wheel, and grind disk...... all work pretty quick on metal
rust dust & metal will fly everwhere.... wear dust mask and eye protection
I am amazed by what grinders can do.... I have one set up with each of the 3 attachment tools saves set up changes.
Again youtube could show you much on the griders too once you know the words to ask for help on
1 - 20 of 21 Posts
