1 - 3 of 3 Posts
Hello Everyone. 01 tundra truck, new alternator. New battery, sometimes truck will start ok, most of time just click,click.
If we have a jump from a helpful person, starts everytime, we do carry around a jumper box,
Any suggestions why??
Starter solenoid in fuse block inside engine compartment would that be a possibilty??
Volt meter shows 12.7 volts.
New battery from autozone.
Its like just a few extra volts allows it to start with the jump
Please advise.
Goon
1995 T100 2WD
Which motor? Could need new brushes or plunger in the starter motor(contacts depending on motor) .
What condition are the battery cables in?
Check the ground cable, both ends. what's the voltage at the battery via a multi-meter?
Possible internal corrsion of the cables increases resistance that the small extra jolt of a jump maybe enough.
Please advise.
Goon
Good Day All, In the fuse box, there is a blue relay called a starter relay, being of sound mind and body, i took it apart to find a nasty looking carbon build up of funk on the "points contact" , probably could of cleaned it, but off to the local parts store, bought new relay 30 dollars, My beloved truck starts just fine now.
hope this helps someone else.
The BIG Goon
1 - 3 of 3 Posts
