1 - 7 of 7 Posts
I recently used information I found on this site to replace the valve cover gasket on my 2002 Camry with 265,000 miles. Anyway, I'd also searched for a video of the procedure and only found one video that wasn't too good. I decided to record myself replacing the gasket in case others could benefit from the video.
http://youtu.be/GlPrABppqPI
-Adrian
Goes Against The Grain
02 Camry SE V6
Good job! The 4cyl is so much easier than the 6!
I see you also like to live dangerously...doing engine work in a white shirt..haha.
Super Moderator
2005 Corolla CE
I'll add it to the DIY sticky later
That light colored shirt (Gray) is actually an old shirt. It has paint, grass stains, grease stains, etc. If you notice, the shirt actually changes half way through the video. I realize I have on a black tee shirt with no stains and I wanted to avoid putting the first one on it.
-Adrian
Super Moderator
2005 Corolla CE
Stickied. FYI this will work just fine for 2002-2009 models w/ the 2AZFE engine.
Also:
The valve cover gasket is the same for all 2002-2014 2AZFE engines including the 2AZFXE Hybrid engine.
Part numbers:
OEM Toyota - 11213-0H010
BeckArnley - 036-1639
Fel-Pro - VS50530R
Victor Reinz - VS50362
I have used all of them with good results.
1 - 7 of 7 Posts
