I was trying to install a cheap $61 Scytek 5000RS over the weekend, mainly for keyless entry, but it also comes with Alarm, and remote start. i was looking at the alarm wiring diagram for 2002 to 2004 camry, and for remote starter wires,
http://www.commandocaralarms.com/wiring/2002-2004/Toyota/Camry/1513.html
for starter 2 and ignition 2 both indicate it is black/yellow (20gauge) at ignition switch harness, when i physically look at the harness, i found 2 black/yellow wire. i hookup everything according to scytek installation, and initially the car will remote start, then shut off right away, i was very puzzled, and then i tried tap only one black/yellow wire, the remote starter wouldn't work at all, then i tap the other black/yellow wire, and finally works
the funny thing is everytime i push the button to remote start, during first attemp remote start, the engine start right up and running for about 5 seconds, then shut off, then 8 or 10 seconds later, system auto try 2nd attemp remote start, and engine starts and now stays running.
anyone encounter similar issue?
also, does anyone know if 2002 LE has built in trunk release motor?
the diagram i found for 2003 indicates it is White/blue (+) at driver side kick panel
http://www.the12volt.com/installbay/forum_posts.asp~TID~53665
i tried it and it blown me a fuse.
anyone has any input, realy appreciated
thanks.
thanks.
