Hello! Some Camry questions!
I have an '02 SE with a 3.0 V6. About 3 months ago, my check engine light came on. I took it to Auto Zone and they read the code and it was my Mass Air Flow Sensor. They suggested cleaning it before changing it because that would usually solve the problem. So I cleaned it, and after about 3 days, the check engine light went out and all seemed good. Then about a month ago, the light came back on. Had it read again and it was the MAF sensor. Cleaned it, light went out, all good. Then a week and a half later, light was back and still reading MAF. At this point, I knew cleaning it was no longer working. I spent $140 on a new sensor and air filter and changed them both myself on a Tuesday (9/27/22). Since I had to disconnect the battery to change it, when I hooked the battery back up, the light had went out and I drove it the rest of the week with no issues... was running really good actually. Then that Saturday (10/1/22), the light came back. I'm like, "GRRRRRR!!" at this point. Took it back to Auto Zone for a code read. Now they're saying it's the EGR valve.
They told me it's not an urgent fix and I can drive the car. And I have been. It only takes me about 7-8 minutes to get from home and work and I don't really go anywhere other than that except for local errands around town. It doesn't seem to be running badly, but I've noticed if the engine is cold, like when I first start it, I have to let it run for about 7-9 minutes to warm up. If I try to drive it cold, I hit higher RPMs before it will shift. Once it's warm, that is no longer a problem.
So I'm wondering....does the EGR have something to do with cold engine/shifting thing? And how will I know it's really time to do something about fixing it? Will it start running weirdly that will let me know, because right now, it seems to run ok. And one more thing... I have NO IDEA where this part is on my car. Anyone know??
Thanks for any advice!
Signed,
Just a woman trying to figure out her car 🤪
Signed,
