For a little while my camry was having some problems with slightly lower power and an oil leak, so I opened up the valve covers on the front and rear to replace the gasket, and saw that the interior was absolutely caked in sludge.
After about an hour cleaning I was happy with the reduced sludge and put on the new gasket, replaced spark plugs and put the cover on. Car had idle problems and I fixed it by cleaning the air intake manifold/valve.
The oil leak did not stop and I eventually narrowed it down to the timing belt camshaft oil seals. Replaced both and the timing belt and water pump because previous owner obviously didnt take care of the car.
Car had problems starting, would randomly stop while driving and had massive loss of power at high rpm. I re-did the timing belt and sure enough it was off by about 5 teeth on the crankshaft.
The engine would also smoke a little and would overheat which I fixed by just adding more coolant.
After I re-did the timing belt it still had issues and I bought a new, OEM timing belt. (Never buying belts from autozone/advance auto parts again)
Now, the car runs fine and doesnt smoke like it did before, but during the test drive I noticed that it would have some idling problems, which i didnt really worry about cause they werent major and now it has a tapping/ knocking sound coming from the valve cover.
I opened the belt up again and it was off center, after re-centering it, I started the car and the tapping is still there, but some rubbing sounds are gone.
I used the screwdriver trick and narrowed it down to the center of the front valve cover. It sounds like a deep knocking. It goes away with added RPM and sometimes fades out and comes back. Ive noticed after running the engine for about 10 minutes on idle it started to become a bit more constant but it still sometimes fades out.
Im thinking it could be the timing belt tensioner or something with one of the gears in the valve cover.
This car has given me a lot of trouble over the last few months and im about to start driving it around since it works, and i dont want to send it to a mechanic just to be given a thousand dollar bill...
Thanks,
Aleksey.
Thanks,
Aleksey.
