i recently purchased my car and i am having an issue with my steering.
when i drive the car the wheel seems "floaty" around 40-45mph, if i turn the wheel i some times get a light binding clunk in as little as a 1/4 turn from straight, or even very slow just driving straight in a lot. the other day i was backing out of a space and when the wheel was returning to center it stuck for a second and needed a little push, also the wheel tends to quickly return to center kind of aggressively, don't know if that is normal? i had my mechanic drive it, he reproduced the bind, and said he didnt notice the floating feeling, but could not locate it, and said i should have the techs look at it when i go to get tires and an alignment tomorrow.
anyway in diagnosing i came up with some more info, with the car on stands, i can reproduce the noise by locking the wheel all the way to the left, and rocking the wheel a 1/4 turn, you can feel the bind in the wheel, and see the tire jump a little, and the noise is most pronounced on the driver side, this can be reproduced with the motor running or not.
i think the previous owner was chasing this as well because it has new quick struts both sides, new sway bar links, new sway bar bushings, and a new pass side control arm and ball joint.
any help would be greatly appreciated
