We're going to need a new set of tires for the Corolla. The current tires are fairly worn and I have a feeling the wheels are slightly bent because there's vibrations above 60 mph (even after having them balanced).
So I'm thinking this would be a good time to get a fresh set of wheels AND tires.
What are the specs for the stock wheels? 14x6? ET? Weight?
I'll probably go with a 15x6.5" ET 38 wheel and put some 195/50/15 falken ziex 912s. Does this sound reasonable? I read that some people here recommend 195/55/15s, but the rolling diameter of 195/50/15 happens to be closer to the rolling diameter of the stock 175/65/14s.
A few new wheel/tire packages from Discount Tire Direct go for $500-$550 shipped and include hub centric rings and new lug nuts. I shopped around for used stuff locally, but I didn't come across anything worth buying.
Any input is appreciated! Thanks!
