Hello everyone. I bought a 2002 Corolla CE 1.8L, 3 speed, 168,000 miles that didn't run in hopes of repairing it. I picked it up from the guys "mechanic" and he said it needed an injector and the valves are burnt. Everything looked good otherwise. Oil was a little dirty but no contaminants, no water in the oil, no fuel smell. The coolant looked good. The engine compartment was fairly clean and looked unmolested. The car will start right up and then immediately stall out. I've looked at multiple postings on various forums and haven't found anything quite like this. The closest thing I saw was a "Toyota start then stall", but it would run if the accelerator was floored. This is not the case. If I start with no pedal, it will start and run for about 1 second just fine, then stall. If I press on the pedal after start, it will stall immediately. The next attempt right after that will start right up and will run for 2 to 3 seconds then stall, so I'm leaning toward a fuel issue but the fuel pressure before the injectors is ~45 psi. When it starts and runs, the pressure will drop only about one pound to 44 psi. The injector nozzles are clean and the resistance is within spec for each injector. It will run like crap on starting fluid.
I really don't want to keep throwing parts at it and I'm confident that it's something simple; I just can't figure it out. There are no codes showing unless I disconnect something (sensor) to test it, then that particular code will pop up (IAC, TPS, MAF, etc.). All of those are testing normal according to the book. I first had a MAF code and IAT code when I brought it home so I just replaced that with a new aftermarket one. Still no luck. When I put the old one back in, no new code popped up so I assume that the guy before me tried replacing it already. I picked up a used ECU from the junk yard but that didn't do anything either. I'm getting spark at all four coils, the spark plugs are clean (fairly new) and the gap is correct. I tried repairing all of this before addressing the valve issue because it would start right up and sound good. But since I still wasn't having any success, I ended up pulling the head and replacing one valve that had a small piece missing at the sealing surface. I thought maybe the ECU was either trying to adjust the valves or cutting fuel/spark to compensate for a misfire? I have it all back together now and the problem is still there. Each cylinder has ~125 psi compression now but the symptoms appear to be exactly the same as before.
Has anyone ever experienced something like this before or have an idea of where to go from here? Even though the various sensors appear to be okay, is it likely to be faulty and still pass resistance tests? I was thinking the IAC valve might be the culprit but holding down the accelerator should bypass that problem, according to other posts.
