IIRC, the entire bezel will have to be popped out. Take the ashtray out first, then pull from the bottom first and work your way up. You'll have to disconnect the wire harnesses to the cigarette lighter and clock. Then you'll see four 10-mm bolts that secure the brackets that the radio is attached to. Remove those and disconnect the antenna and radio plugs.
1 - 2 of 2 Posts
