Thank you for reading my thread and I appreciate any help y'all can provide!
I have a 2002 Toyota Camry LE 4 cylinder. For the past 4 years (or more) I have had a hard thud sound that comes from the front right tire portion while I am driving and when the car goes over uneven surface, pot holes, ridges on roads etc.
I ignored it for the longest time and finally decided to get it checked out and a local mechanic shop said I needed new struts, another said I needed new sway bar link.
So anyway my tires were getting worn out and it was time for new tires, as well as struts (still had the original struts since I bought the car new in 2002, currently has 95,000 miles on it).
So I got the struts changed on both sides (fitted the monroe sensa tracs) + got new tires (all 4) and got wheel balancing done. The noise still didn't go away.
So then I went ahead and got the sway bar link also replaced (both sides). The noise still is the same. I got the tie rod ends examined and they look fine.
The noise is a hard thud, if I drive at very low speeds say at 5-15 miles per hour, you cant hear it, if I go over 20 miles an hour and even if it is a small ditch, a pothole, a crack in the road, I hear the thud and some rattling (like some thing is loose).
I have got everything examined and no one can seem to find anything wrong. The mud flaps or any other portion is not loose nor is it hitting the inside of the tire.
I am dejected, frustrated and lost.
Any pointers, help, advise would be appreciated.
Should I take it to a Toyota dealership and have them check it out?
Thanks much!
Thanks much!
