1 - 7 of 7 Posts
First time on site so I'm open to comments to what I might be doing wrong but hears my question: I just bought a 2002 Toyota Prerunner DoubleCab 4-Door and I can't find the module for the keyless entry, mine has it but it's not working so I wanted to troubleshoot the system but I can't seem to find it? Any help would be greatly appreciated.
01 & 04 S-Runners
What makes you believe you have remote keyless entry? Keyless entry wasn't a factory option until the 2003 model year (with the Power Package). Do you have an aftermarket system installed or something? ....
keyless entry
I went through the testing process that Toyota had me go through and when I finished if the locks locked and unlocked once by themselves they said I had a factory unit and it did so I do.
01 & 04 S-Runners
In that case, look down in the area behind / around the left kick panel. That's where the TVIP ECU ought to be ...
Thanks but I've already looked there and it's not there, don't worry about it I'm going to have a new aftermarket unit installed but thanks anyway
Discussion Starter #6
Where you from in Ohio, I was born and raised in owensboro, ky and I was just back there about 4 weeks ago, dam what hell damage they got, I was living there when the two F-3 tornados went through o'boro in Jan. 2000, my house was one of the first houses hit when the tornados came into the city limits.
02 DubCab 4x4
I couldn't find mine either. I bought my truck used with just a key for the ignition and no key fob. I am pretty sure mine has it because I have power door locks, power windows, and my key with one turn locks or unlocks all of the doors simultaneously.
maybe i should just get a key fob off of ebay and go thru the programming instructions that they give??
1 - 7 of 7 Posts
