Hi...
I bought my used RAV in April and, on July 31st, the Engine Malfunction Indicator went on. On the highway and about to go on a road trip the next day, I pulled right into Can Tire for diagnosis. The verdict was the O2 sensors in front of and behind the catalytic converter. They said "it happens" and that it was not a big deal and not to worry about it on my trip.
Over the last 5 months, it goes on and off at will. I had it diagnosed a second time in September and was again told not to worry about it.
I did some research in the fall and found out that the 2002 RAVS, that came out of a specific plant (identified by a 6 in the VIN if I remember correctly). As I remember it, the problem was with a weld in the exhaust pipe and that this was causing my problems. I had taken a printout of the web page where I found that info but, as luck would have it, I was at work and forgot to pick up the printout. When I went back the next day, the printout was long gone and, unfortunately, all references to that web site were also (and I thought that I bookmarked too many pages). To this day, I have not been able to find that information on-line.
So...my question is...what do you guys know about this? I am planning on calling Toyota to see if there is a campaign on the issue but wanted to see what I could find out from you first. Is anyone else experiencing this issue?
Thanks.
Holly
