Except for the valet key, which can't open the glovebox and the trunk, all keys should be the same!
You can have a locksmith recode yours to the same key of course!
Yeah so I just realized at the dealership the ignition must’ve been replaced. That explains the two different keys but I want to recode the ignition cylinder now. Where can I buy the tumbler discs? I cannot find any onlineExcept for the valet key, which can't open the glovebox and the trunk, all keys should be the same!
Thanks but it says it’s not compatible with 2003 corollaNever use them before, but you can see if they have what you need:
Toyota Wide Tumbler Replacement Kit for Split Tumblers (A-30-117)
Toyota Wide Tumbler Replacement Kit for Split Tumblers (A-30-117) This is a supplemental kit for the A-30-108 kit. This kit contains special design wide tumblers to replace the side-by-side split tumblers in Toyota locks using TR47 keyway with code series 10001-15000 These tumblers have been...www.clksupplies.com
thanks![]()
1992 - 2019 Toyota TR47 / TOY43 / 8 Cut / Ignition Lock Wafer Set (AFTERMARKET)
KLF-LWS-TOY04 This is a Toyota Ignition Lock Wafer SetNo Springs IncludedManufacturer: Keyless Factory Includes 4 different sizes, 20 pieces of each size: 4 full size (#1) (#2) (#3) (#4) Compatible with the Following: 2007 - 2008 Pontiac Vibe 2013 - 2016 Scion FR-S 2013 - 2019 Subaru BRZ 1996 -...www.uhs-hardware.com
