Yes it finally happened with 89K on the car. I had a 2000 Avalon and this same sensor failed between 85K and 90K. I've been dreading this one, but after reading a good thread about it here on T/N, and going out and looking at the problem, I have gotten confidence that I can do it. It may not be as tough as I thought, and I'm wondering if I even have to remove the air filter cover and the air resonator which is the standard procedure when getting at the sensor from the top. I removed the TPS cable and I moved the brake booster line above the hood, and it seems to be enough room. I won't know until I order the sensor and try to install it. Thanks to T/N for this great thread about it:
http://www.toyotanation.com/forum/1...-rear-bank-air-fuel-o2-senor-replacement.html
I'm almost certain this is the sensor for my car:
https://www.amazon.com/Denso-234-9021-Oxygen-Sensor/dp/B000C5YD42
I went down and took some pictures tonight...
A/F sensor near firewall
Connector
TPS cable removed
Brake booster hose and TPS cable removed for better access
Trying to save my back here--old man at work
It will take maybe a week to get it from Amazon. I think this is also what has caused the car to hesitate when I accelerate, and I know it is why my fuel mileage has dropped by 3MPG. As long as those threads are OK in the rear exhaust manifold, I think I can do it. We well see...
Connector
TPS cable removed
