removing Panel
Here is how I remove mine on 2004. Two push pins on outside of door. Push pin in the middle and then pry them out. Next there are two screws on the side by the hinges. Pry the covers off then use phillips screwdriver. Next you have to take the cover off the handle. there is a phillips screw in the middle that may be covered by a small square of plastic. take that out. Then get a very small flat head screw driver. On the side the handle hinges there is a catch on the top and the bottom. If you put the screwdriver on the inside of the handle and pry out, it will release the catch and you can remove. Then pry out the handle assembly. There is a phillips screw underneath in the middle that must be removed. There is a wire harness attached to the bottom. Simply press the nob in the middle and pull this off. Then take of the screws on the bottom of the door. I have 3. Now simply lift up to get the panel out of the door track. Do not pull it away as there is one more wire harness connector for the light on the bottom of the door that you must disconnect.
Hope this helps.
