I recently replaced all four struts with brand new Monroe OE-Spectrum struts. All 4 new KYB bump stops.
Used my original Toyota coil springs and coil insulators. Two front mounts were in good shape and bearing were in good shape also.
I did not have any clunking noise before I changed the struts. Now I hear clunking noise from from end basically from both from ends.
All coil springs and mount sat properly. What can be wrong? I tried to make the center bolt as tight as possible. Max is 36 ft-lb torque.
Only thing I did not do is, I did not use the new bolt that came with Monroe ( look very cheaply made). I used the original Toyota bolts for the two front struts.
