1 - 3 of 3 Posts
Car starts but no rpm available, car is an automatic, computer was just replaced. It seemed to do the trick for a couple of days to solve the problem but now back to square one.
Look in sig
The car RPM gauge on the dashboard cluster doesn't work?
If so, it might be a bad connection. You'll need to get a multi meter and a wiring diagram of the pin layout of the Corolla cluster connector.
06 HiHy,13 Prius
I'm with Kingdom.... you need to be more specific. Does the engine not rev up, or is there simply no reading on the tachometer?
1 - 3 of 3 Posts
