1 - 7 of 7 Posts
I have a 2004 Highlander Limited V6 with front factory heated seats. They work, but they are very weak. It takes a little bit to warm up and then they seem to turn off for a while, maybe 15 minutes or so. Almost like there is a thermal switch that opens up. The light on the switch stays on when the switch is on. Anyone know how to fix this? If there is a thermal switch I could bypass it.
All the brains are in the seat itself. There is only a power and ground wire so maybe the heating element has seen better days. Probably has to be opened up. The system is almost identical on all Lexus / Toyota so I would see if someone else has had the same issue.
I might be wrong but I believe someone has done this here a while back. I know Dorman and a few others make a heating element kit. There is a large pad in the seat back as well, do you find that one works consistently and the bottom one doesn’t, or do they both not work properly?
Discussion Starter · #5 ·
They both work the same, butt and back, very weak. It is like they come on for a few minutes and then turn off
1 - 7 of 7 Posts
