1 - 8 of 8 Posts
Hi all,
anyone knows what is the bolts size for the hitch fixation ???
thanks
i am not sure if thats metric or english treads
gervais
2015 Sienna / 2018 RAV4
You will most likely need to chase the threads with a tap and a lot of cutting oil. Go gently, as those threads have to hold your hardware tight, and after 15 years are likely damaged by corrosion.
well
thanks for your informations,
12mm is about 3/8
1.25mm is fine tread
40 mm is about 1.25,,,1.5 inch
would you know the "grade" of the bolt?
i am used at using Grade 5 bolt ,,,in my standard
thanks for your help
gervais.
Discussion Starter #6
humm yes grade 8 should be a minimum,
i am not sure i will found these around,i am living in a rural zone where there is not much
specialized stores,,
thanks anyway ,
gervais
We installed our hitch at the 15 year mark and yeah, all bolt holes were rusted and needed tapping due to corrosion. Good luck.
Greg
1 - 8 of 8 Posts
