1 - 2 of 2 Posts
G
I have a leak in my left rear shock and need to have it replaced. So
far, three different mechanics have told me three different repairs I
need. The most costly one is $1,400 to replace the left rear, left
front, and the gear box. Another place said it was not the shock and a
hydraulic problem and should be covered under the warranty. The third
place said I need the two shocks and a controller (assume it the same
as the gear box) for $1,300. I know I need the repair done but just
want to make sure I need all this work done and shell out the big $$$.
Any advice would be much appreciated. Thanks.
G
Discussion Starter · #2 ·
"mikecinmd" <[email protected]> wrote in message
news:[email protected]
Which suspension do you have in your 4Runner?
Shock absorbers should be replaced as pairs on a particular axle, in other
words, replace both rear or both front at the same time.
If you are getting 3 different opinions on what is needed for a repair, find
out which one will guarantee that their repair will work. Unfortunately, I
doubt if anyone in this group will be able to diagnose your vehicle without
actually seeing it first hand.
As far as whether it is covered by warranty, if the vehicle is less than 36
months old from the date of first use and has less than 36,000 miles, it
should be covered by warranty unless something damaged it.
Ray O
1 - 2 of 2 Posts
