1 - 4 of 4 Posts
i’m trying to install these halogen led rings around the head lights the only way i can se it being done is by removing the actual clear headlight lens to get into the head light i tired some what by removing the clips to pry it open but their brand new headlights i just bought so i got a little nervous wanted to check see if anyone has ever done this or maybe i’m just in dummy mode and there is a softer easier way to do this??? ??? thank you T Nation
good to know thank you! i just noticed the little clips on the front of them so it got me thinking maybe they pop off because i have after market oem specs
1995 T100 2WD
One T100 owner took an old headlamp and used a fine die grinder wheel and went around the perimeter and cut it open, installed a projection lamp from ?? and the glued the lens back together, sanded, buffed and polished it.
It did turn out nice but even he mentioned it took longer than he expected. They have yo be sealed up to prevent condensation and water/weather issues.
1 - 4 of 4 Posts
