1 - 15 of 15 Posts
I have a 2005 Toyota Corolla S. Somehow I blew a fuse that works the backlights for the AC controls, transmission selector. So I have no lights at night to change environmental (AC, Heater, etc). I have checked all the fuses in the fuse box under the dash and under the hood. Any help in locating a fuse for the environmental control backlights?
Also, how do you clear the "Maintenance Required" light after changing oil?
Thanks
Mark
2005 Corolla CE
reset maintenance light
It's very difficult to search out in the manual but to reset maintenance light you turn the ignition key to off with odometer reading showing (not trip). Turn the ignition key to the on position while holding down the trip meter reset knob. Hold down the button for at least 5 seconds. The odometer indicates 000000 and the light goes off. Fuses are a hassle under steering wheel but with a light and a mirror and small hands they can be changed. Good luck. Marg
Maint light:
Keys out of ignition switch
push and hold trip odometer fo 5 sec / insert key turn to first "click" hold for 5 sec / turn to RUN (no need to start the car) hold until light goes off.
You should be good for another 5,000 miles.
(This is off the top of my head - did it this weekend... car is parked 30 miles away where the written instructions are)
EDIT: Opps, was already answered... sorry
Thanks
Mark[/QUOTE]
To reset the Maintenance light:
Push in the millage button "hold that button", and turn key
NOTE U don't have to start the motor
Yusef
Does anybody know where the fuse for the headlight is? I THINK i blew the fuse for passenger side low beams, i bought new halogen still no lights yet the bulb is good.
Try looking under the hood, just behind the Battery u will c a black box. Pop the top off of that black box there is a lot of fuse's.
If it's not located in that box there is another spot for fuses. As your setting in the driver seat open the little compartment on your left "just past the left side of the streering wheel" I put change in that little compartment. Remove the pull down lid, note u now have to get on the floor board and look up 2 c the fuses located in this area.
I hope this helps JANABRATT :cool:
Great! it works now the fuse was blown
1 - 15 of 15 Posts
